跳转到主内容
加入维修社区 - 创建账户
Logitech UE Hyperboom DC Power Socket Replacement
你所需要的
  1. Logitech UE Hyperboom DC Power Socket Replacement, Handle: 步骤 1 中的图像 1,2 Logitech UE Hyperboom DC Power Socket Replacement, Handle: 步骤 1 中的图像 2,2
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    询问修复机器人
    添加评论
  2. Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: 步骤 2 中的图像 1,2 Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: 步骤 2 中的图像 2,2
    • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
    询问修复机器人
    添加评论
  3. Logitech UE Hyperboom DC Power Socket Replacement: 步骤 3 中的图像 1,3 Logitech UE Hyperboom DC Power Socket Replacement: 步骤 3 中的图像 2,3 Logitech UE Hyperboom DC Power Socket Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
    • Pull the panel off to access the internal components.
    询问修复机器人
    添加评论
  4. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: 步骤 4 中的图像 1,3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: 步骤 4 中的图像 2,3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: 步骤 4 中的图像 3,3
    • Unscrew the top 11.7m screw on the DC Power Socket panel using the Phillips #0 screwdriver.
    • Use the Jimmy to pry the panel away from the speaker, then disconnect the power cables from the daughterboard.
    询问修复机器人
    添加评论
  5. Logitech UE Hyperboom DC Power Socket Replacement: 步骤 5 中的图像 1,2 Logitech UE Hyperboom DC Power Socket Replacement: 步骤 5 中的图像 2,2
    • Remove the four 7.9mm screws from the daughterboard with the Phillips #0 screwdriver.
    • Pull the circuit board away from the panel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
G'day I've got the 2024 version that has a broken charging port and can't find a PCB replacement anywhere I'm in New Zealand probably why but do you guys reckon I could just swap it out with the older version of the charging board since there available.
Ethan Donaldson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 43
总计 163
