跳转到主内容
加入维修社区 - 创建账户
Logitech TK820 Keyboard Disassembly Guide
你所需要的
  1. Logitech TK820 Keyboard Disassembly Guide, Backside + 1x Visible Screw: 步骤 1 中的图像 1,2 Logitech TK820 Keyboard Disassembly Guide, Backside + 1x Visible Screw: 步骤 1 中的图像 2,2
    • To start, flip the keyboard onto its back side, remove the battery cover, and remove all batteries.
    • There is one visible screw between the two battery bays - start by removing this
    询问修复机器人
    添加评论
  2. Logitech TK820 Keyboard Disassembly Guide, Screws behind feet: 步骤 2 中的图像 1,1
    • The next series of screws are behind some of the rubber feet. Feet with screws under them have been circled in orange.
    • Remove the top-left rubber foot (cylindrical bump end, side away from the battery slots) and remove the screw underneath it.
    • Remove the three bottom-rightmost rubber feet (non-cylindrical-bump end, 3x feet closest to the battery slots side) and remove the screws underneath.
    • You don't need to remove any of the other feet - there's nothing under them
    询问修复机器人
    添加评论
  3. Logitech TK820 Keyboard Disassembly Guide, Heat gun + prise open: 步骤 3 中的图像 1,3 Logitech TK820 Keyboard Disassembly Guide, Heat gun + prise open: 步骤 3 中的图像 2,3 Logitech TK820 Keyboard Disassembly Guide, Heat gun + prise open: 步骤 3 中的图像 3,3
    • Beyond the screws just removed, the keyboard is glued shut, and the frame is also held closed with a number of small plastic clasps.
    • The teal shaded sections of the picture of the keyboard back show the areas where the glue is, and the purple shows the ribbon cable (which also has glue on it) - aim a heatgun at these before attempting to prise the keyboard open for best success.
    • The plastic clasps are shown in orange around the edge of the same picture. They should come apart quite easily with a spudger but be mindful of where they are as you begin to prise the keyboard apart
    • Continue prising the edge and heatgunning the back and inside of the keyboard until it comes apart fully
    • Don't try and remove the blue plastic strip around the edge until the next step, as it is screwed in.
    询问修复机器人
    添加评论
    • The blue strip around the edge of the key tray is secured with one screw at either end of the cylindrical bump top of the keyboard - remove these and the strip should come out easily
    询问修复机器人
    添加评论
  4. Logitech TK820 Keyboard Disassembly Guide, Unscrew and remove PCB: 步骤 5 中的图像 1,2 Logitech TK820 Keyboard Disassembly Guide, Unscrew and remove PCB: 步骤 5 中的图像 2,2
    • The PCB / control board for the keyboard is held down by two final screws, and also by the negative battery terminal just to the side of it.
    • Remove the screws, then push the negative terminal wire down enough to unhook it from the plastic clip it is in. Once unhooked, the PCB should lean out with ease.
    • The cables connecting the trackpad and keyboard to the PCB are secured with small latches which can be slid out to remove the cables.
    • Note that the on/off switch on the PCB slots in to the physical switch going through to the front of the keyboard - it will need to be angled back in to the same right spot when re-assembling.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Stewart Webb
于02/26/24注册
121 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 28
总计 28
