跳转到主内容
加入维修社区 - 创建账户
Logitech Performance MX Disassembly
  1. Logitech Performance MX Disassembly, Remove the Mouse Feet: 步骤 1 中的图像 1,2 Logitech Performance MX Disassembly, Remove the Mouse Feet: 步骤 1 中的图像 2,2
    • Peel off the three thin, plastic mouse feet on the bottom of the mouse. Make sure to carefully remove the adhesive along with the pad.
    • Use a thin flat object such as a flathead screwdriver to help remove if necessary.
    询问修复机器人
    添加评论
  2. Logitech Performance MX Disassembly, Remove the First Four Screws: 步骤 2 中的图像 1,2 Logitech Performance MX Disassembly, Remove the First Four Screws: 步骤 2 中的图像 2,2
    • Using a screwdriver, unscrew the four screws that were under the mouse feet.
    • Remove the battery from the mouse if not done already.
    询问修复机器人
    添加评论
  3. Logitech Performance MX Disassembly, Separate the Top and Bottom: 步骤 3 中的图像 1,3 Logitech Performance MX Disassembly, Separate the Top and Bottom: 步骤 3 中的图像 2,3 Logitech Performance MX Disassembly, Separate the Top and Bottom: 步骤 3 中的图像 3,3
    • Gently pull the top of the mouse off from the base, making sure the wires and components are in place.
    • Carefully pull out the white enclosure from its port to safely take the top apart from the bottom.
    询问修复机器人
    添加评论
  4. Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: 步骤 4 中的图像 1,2 Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: 步骤 4 中的图像 2,2
    • Pull out the plastic pin in-between the scroll wheel and the battery enclosure and pull up on the scroll wheel base to remove.
    询问修复机器人
    添加评论
  5. Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: 步骤 5 中的图像 1,2 Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: 步骤 5 中的图像 2,2
    • Remove the 2 small springs underneath the scroll wheel base.
    • Unscrew the four screws holding the battery capsule onto the PCB.
    添加评论
  6. Logitech Performance MX Disassembly, Unplug the Ribbon Cable: 步骤 6 中的图像 1,2 Logitech Performance MX Disassembly, Unplug the Ribbon Cable: 步骤 6 中的图像 2,2
    • Unplug the ribbon cable from the circuit board. Be careful to not remove the cable’s locking mechanism.
    询问修复机器人
    添加评论
  7. Logitech Performance MX Disassembly, Remove Scroll Wheel Support: 步骤 7 中的图像 1,2 Logitech Performance MX Disassembly, Remove Scroll Wheel Support: 步骤 7 中的图像 2,2
    • Unscrew the four screws to take out the black scroll wheel support in the center and the two black pads that lie on both sides of the support.
    询问修复机器人
    添加评论
  8. Logitech Performance MX Disassembly, Pull Up Circuit Board: 步骤 8 中的图像 1,2 Logitech Performance MX Disassembly, Pull Up Circuit Board: 步骤 8 中的图像 2,2
    • Pull the circuit board up to find the on and off switch. Take out the clear plastic bit that held the springs.
    询问修复机器人
    添加评论
  9. Logitech Performance MX Disassembly, Disassembly Finished!: 步骤 9 中的图像 1,1
    • All parts should be visible to repair or for replacement.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
1指南评论
Although useful, sadly this guide does not show how to disassemble the upper parts where the 3 switches for zoom, back and forward are located. Step 3 is the only place that shows this area, but only focuses on the disconnection of it.
Phil Millard - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 45
过去 30 天: 125
总计 5,461
