跳转到主内容
加入维修社区 - 创建账户
Logitech MX Keys Feet Replacement
你所需要的
  1. Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: 步骤 1 中的图像 1,3 Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: 步骤 1 中的图像 2,3 Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: 步骤 1 中的图像 3,3
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your keyboard.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
  2. Logitech MX Keys Feet Replacement, Remove the feet: 步骤 2 中的图像 1,2 Logitech MX Keys Feet Replacement, Remove the feet: 步骤 2 中的图像 2,2
    • Heat an iOpener and lay it on the top left foot for one minute.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic.
  3. Logitech MX Keys Feet Replacement: 步骤 3 中的图像 1,3 Logitech MX Keys Feet Replacement: 步骤 3 中的图像 2,3 Logitech MX Keys Feet Replacement: 步骤 3 中的图像 3,3
    • The foot should come up without much force. If it feels stuck, apply more heat and try again.
    • Insert the point of a spudger under an end of the foot.
    • Push the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it.
    • Repeat the process to remove the remaining feet.
    • If you're replacing the battery, you only need to remove the feet along the top edge.
  4. Logitech MX Keys Feet Replacement, Reassembly information: 步骤 4 中的图像 1,2 Logitech MX Keys Feet Replacement, Reassembly information: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    • To install the feet during reassembly:
    • Use a pair of angled tweezers to peel up and remove all the plastic film from the foot recesses.
    • If you're installing new feet, remove them from their backing and firmly press them into place.
    • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
结论
2等其他人完成本指南。
Spencer Day
于09/14/22注册
160,329 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,996篇指南
1指南评论
Where do you buy replacement 'feet' for the MX Keys?
maxtraxpro - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 83
过去 30 天: 358
总计 4,398
