跳转到主内容
加入维修社区 - 创建账户
Logitech MBJ58 Mouse Button Replacement
你所需要的
  1. Logitech MBJ58 Mouse Button Replacement, Mouse button: 步骤 1 中的图像 1,1
    • Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
    • Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
    • YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
    询问修复机器人
    添加评论
    • Loosen the Phillips screw in the bottom.
    询问修复机器人
    添加评论
    • The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
    • The motherboard is just plugged in and can be carefully removed forwards and upwards.
    询问修复机器人
    添加评论
    • Sensibly, first clean everything (dry).
    • Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
    询问修复机器人
    添加评论
    • Everything should click together again and screws can be screwed back in. -> Loooift.
    询问修复机器人
    添加评论
结论
Repeat the steps in reverse order to reassemble your device.
取消:我没有完成这个指南。
另外一个人完成了本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tho. Hummet
于04/05/18注册
121 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 37
总计 695
