跳转到主内容
加入维修社区 - 创建账户
Logitech M705 Button Failure Fix
你所需要的
    1. Logitech M705 Button Failure Fix, Dissassembly and problem identification: 步骤 1 中的图像 1,2 Logitech M705 Button Failure Fix, Dissassembly and problem identification: 步骤 1 中的图像 2,2
      • Follow the teardown guide to disassemble the mouse
      • The pad in the upper shell of the mouse that presses on the microswitch has worn , circled red in the photograph. Comapre the wear on this side with the lower level of wear in the equivalent part for the right hand mouse on the left side of the photograph. A close up of the worn part is shown in thhe second photogrpah
      询问修复机器人
      添加评论
    2. Logitech M705 Button Failure Fix, Use of insulation tape to resolve problem: 步骤 2 中的图像 1,1
      • Use electrical insulation tape (blue in the photographs) to build up the level of the worn pad. Here I've used four layers
      • Then reassemble the mouse
      询问修复机器人
      添加评论
结论
To reassemble your device, reverse the dissasembly process as per the Teardown Guide.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Nick Knows
于08/08/25注册
115 声望
撰写一个指南
1指南评论
This fixed an issue for me where the mouse buttons were bouncing (double clicking when trying to hold the button down).
user5219 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 37
过去 30 天: 135
总计 843
