跳转到主内容
加入维修社区 - 创建账户
此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论
Logitech M570 无线轨迹球拆解
你所需要的
    1. Logitech M570 无线轨迹球拆解, 拧下螺丝: 步骤 1 中的图像 1,1
      • 拧下 5 颗部分隐藏的螺丝。其中三颗螺丝位于橡胶垫下方,一颗位于电池仓内的贴纸下方(拆卸前需要先撕掉贴纸)。
      • 可以将蓝色轨迹球直接从底座中推出来。建议定期进行此操作并清洁开口处。
      添加评论
    2. Logitech M570 无线轨迹球拆解, 内部构造: 步骤 2 中的图像 1,2 Logitech M570 无线轨迹球拆解, 内部构造: 步骤 2 中的图像 2,2
      • 拧下螺丝后,外壳即可轻松取下。蓝色球体的固定座由一块独立的塑料件构成。电路板由几颗螺丝固定。
      询问修复机器人
      添加评论
结论
按照相反的顺序执行这些步骤,重新组装你的设备。
取消:我没有完成这个指南。
17等其他人完成本指南。
Peter Scholl
于06/26/21注册
2,003 声望
创作了7篇指南
14指南评论
Had an issue where the left clicker was not working great anymore. Followed this guide to take it a part did a little blow out and some rubbing alcohol to for now restore it to the proper working condition! Thanks as I would have never found the screw under the battery sticker.
Jamie Lawson - 回复 分享
Great! Thanks for the feedback - it's really motivating
Peter Scholl - 回复 分享
Hi, the middle click on my M570 was working really bad, sometimes works sometimes not.. but after open the mouse and apply isoprophilic alcohol with a soft brush in the middle switch (the square with red central button), it is working like a charm again.
mouse working again - 回复 分享
Thanks for the information. I am happy you could use the information
More than happy to find this manual, as I was asking official Logitech Support and no positive answer. I disconected the tape between teh upper and lower part - any tips how to reconect it?
I would also never find the fifth the screw under the battery sticker.
Piotr Pawłowski - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 73
过去 30 天: 245
总计 10,966
