跳转到主内容
加入维修社区 - 创建账户
Logitech M331 Disassembly
你所需要的
    1. Logitech M331 Disassembly, Remove the bottom screw: 步骤 1 中的图像 1,1
      • Flip the mouse over so the power switch is facing up.
      • Slide the battery door towards the back of the mouse to release its clips and remove it.
      • Remove the battery (if installed).
      • Remove the sticker from the battery well.
      • Use a Phillips screwdriver to remove the black screw in the battery well.
      添加评论
    2. Logitech M331 Disassembly: 步骤 2 中的图像 1,1
      • Carefully detach the upper case and the lower case of the mouse by holding the lower case and sliding the upper case forward.
      添加评论
    3. Logitech M331 Disassembly: 步骤 3 中的图像 1,1
      • Unscrew the screw in the purple circle and unfasten the plastic pins in blue circles to remove the board from the plastic cover.
      询问修复机器人
      添加评论
    4. Logitech M331 Disassembly: 步骤 4 中的图像 1,2 Logitech M331 Disassembly: 步骤 4 中的图像 2,2
      • To disassemble the upper case of the mouse, detach the plastic pins located in the blue circles. The two pins located in purple circles will be automatically unfastened once the four blue pins are detached.
      • To disassemble the light propagator, detach the small plastic pin at the bottom of the mouse case and light propagator connection.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
24等其他人完成本指南。
garfieldknight
于02/13/19注册
1,157 声望
创作了2篇指南
9指南评论
first time using ifixit
this was just what i needed thanks!
Prentiss Johnson - 回复 分享
Thanks for the guide! I was able to clean the scroll wheel properly and fixed the annoying inaccurate scroll issue.
Gabriel Louie Cubelo - 回复 分享
Exactly what I needed, a clear and direct guide. Thank you so much!
Zıbın Zıbınoğlu - 回复 分享
Finally my mouse-wheel has stopped ghost scrolling, I used to have this problem where when I scrolled down and up it would go the opposite direction, at first I thought it was a bug but turns out on my other wired logitech mouse, it worked normally.
Upon following this instruction manual (A++) I managed to put some WD40 in the mouse wheel scrolling part, from the inside (not the wheel but the thing it’s attached to) and scrolled it a couple of times, now it works normally :)
Thanks to the author!
TAY CHU TSE ANDREW - 回复 分享
Thanks, cleaning up my M331 and put nachi tape on right-mouse-button so it works again (after it deform slightly).
yayanm 1k - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 55
过去 30 天: 221
总计 18,738
