跳转到主内容
加入维修社区 - 创建账户
Logitech M215 Lens Replacement
你所需要的
    1. Logitech M215 Lens Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Logitech M215 Lens Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Logitech M215 Lens Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      添加评论
    2. Logitech M215 Lens Replacement, Remove old battery: 步骤 2 中的图像 1,1
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      添加评论
    1. Logitech M215 Lens Replacement, Top Cover: 步骤 3 中的图像 1,2 Logitech M215 Lens Replacement, Top Cover: 步骤 3 中的图像 2,2
      • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
      • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
      询问修复机器人
      添加评论
    2. Logitech M215 Lens Replacement: 步骤 4 中的图像 1,1
      • Pry the top cover off. You may need to use a pry tool to help.
      询问修复机器人
      添加评论
    1. Logitech M215 Lens Replacement, Motherboard: 步骤 5 中的图像 1,2 Logitech M215 Lens Replacement, Motherboard: 步骤 5 中的图像 2,2
      • Unscrew the 0.25mm phillips head screw to release the circuit board.
      询问修复机器人
      添加评论
    1. Logitech M215 Lens Replacement, Lens: 步骤 6 中的图像 1,2 Logitech M215 Lens Replacement, Lens: 步骤 6 中的图像 2,2
      • The laser amplifier is not connected to the rest of the mouse and can simply be removed at this point.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Hannah Pate
于01/30/15注册
1,742 声望
创作了7篇指南
团队
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 的会员
USFT-WATKINS-W15S1G1
4 名成员
创作了48篇指南
1指南评论
Where i can buy mouse lenses for mk225
Cybermetz X - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 46
总计 2,774
