跳转到主内容
加入维修社区 - 创建账户
Logitech M215 Button Plate Replacement
你所需要的
    1. Logitech M215 Button Plate Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Logitech M215 Button Plate Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Logitech M215 Button Plate Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      添加评论
    2. Logitech M215 Button Plate Replacement, Remove old battery: 步骤 2 中的图像 1,1
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      添加评论
    1. Logitech M215 Button Plate Replacement, Top Cover: 步骤 3 中的图像 1,2 Logitech M215 Button Plate Replacement, Top Cover: 步骤 3 中的图像 2,2
      • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
      • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
      询问修复机器人
      添加评论
    2. Logitech M215 Button Plate Replacement: 步骤 4 中的图像 1,1
      • Pry the top cover off. You may need to use a pry tool to help.
      询问修复机器人
      添加评论
    1. Logitech M215 Button Plate Replacement, Button Plate: 步骤 5 中的图像 1,2 Logitech M215 Button Plate Replacement, Button Plate: 步骤 5 中的图像 2,2
      • Use your fingernail to carefully remove the two skid stickers from the fat (non-button) end of the bottom of the mouse to reveal two Philips head screws. Remove these, then unclip the bottom cover. Don't get the sticky dusty. Now remove buttons; they're both attached by one 0.5mm Phillips head screw. It is located in the center of the top cover.
      询问修复机器人
      添加评论
    2. Logitech M215 Button Plate Replacement, Pry off buttons: 步骤 6 中的图像 1,2 Logitech M215 Button Plate Replacement, Pry off buttons: 步骤 6 中的图像 2,2
      • The button are now only attached by a small overhang near the front. You will need to use the pry tool to push the button plate off of this overhang as shown.
      • The button plate should be able to be completely removed at this point.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Hannah Pate
于01/30/15注册
1,742 声望
创作了7篇指南
团队
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 的会员
USFT-WATKINS-W15S1G1
4 名成员
创作了41篇指南
2指南评论
Step 5 loops back to step 3. If you follow steps 3 and 4 you will break the tabs at the front of the top cover.
In step 4 use the pry tool to loosen the back end of the mouse if necessary but it should just come apart, then slide the top cover out from under the tabs at the front of the base.
Most of step 5 is a recap of steps 3 and 4, the circled screw in the second picture allows you to remove the button plate from the top cover.
Step 6 is only necessary for replacing the button plate or cleaning between the button plate and top cover, the actual switches are on the circuit board
William - 回复 分享
All of this did not help make my left button work. I still hear the clicking sound when I press the button but nothing happens on the screen. I made sure the circuit boards were clean and clear of any debris, but not luck after re-assembling it; right button still works.
Nadder - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 55
总计 6,740
