简介
It is recommended to have the iFixit ProTech toolkit and have already taken the case apart.
你所需要的
在这个步骤中使用的工具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
Using the small end of a spudger, pry out the terminal from the interior of the case.
2等其他人完成本指南。
