跳转到主内容
加入维修社区 - 创建账户
Logitech Gamepad F310 Trigger Spring Replacement
你所需要的
  1. Logitech Gamepad F310 Trigger Spring Replacement, Case: 步骤 1 中的图像 1,2 Logitech Gamepad F310 Trigger Spring Replacement, Case: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    询问修复机器人
    添加评论
  2. Logitech Gamepad F310 Trigger Spring Replacement: 步骤 2 中的图像 1,2 Logitech Gamepad F310 Trigger Spring Replacement: 步骤 2 中的图像 2,2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    添加评论
  3. Logitech Gamepad F310 Trigger Spring Replacement: 步骤 3 中的图像 1,1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    询问修复机器人
    添加评论
  4. Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: 步骤 4 中的图像 1,2 Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove:
    • Four 3 mm screws
    • One 5 mm screw
    • Remove the central silver screw last.
    • Gently lift the motherboard off of the back case and slide the cord out of the top slot.
    询问修复机器人
    添加评论
  5. Logitech Gamepad F310 Trigger Spring Replacement: 步骤 5 中的图像 1,1
    • Make note of the slot on the controller and the slot on the trigger that the spring is connected to.
    • Press the trigger down until the spring pops loose.
    • You may need to fish the spring out of the pocket it is in. The spring will be accompanied by a small black piece that fits inside the spring.
    添加评论
  6. Logitech Gamepad F310 Trigger Spring Replacement: 步骤 6 中的图像 1,1
    • In order to properly place the spring into the controller, make sure that the black piece is inside, and make sure each end of the spring goes into the correct slots.
    询问修复机器人
    添加评论
结论
You're all finished! To reassemble your device, follow these instructions carefully in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
I completed this guide in conjunction with this video:
How to disassemble and reassemble the Logitech Gamepad F310
Khalon - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 108
总计 1,608
