跳转到主内容
加入维修社区 - 创建账户
Logitech G733 Power Button Replacement
你所需要的
    1. Logitech G733 Power Button Replacement, Power Button: 步骤 1 中的图像 1,1
      • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Gently start to pull the left ear pad off, starting from the top.
      • Slide your finger around the edges until it releases completely.
      • Remove the ear pad.
      询问修复机器人
      添加评论
    2. Logitech G733 Power Button Replacement: 步骤 2 中的图像 1,2 Logitech G733 Power Button Replacement: 步骤 2 中的图像 2,2
      • Remove the four screws securing the speaker housing using a T4 Torx screwdriver.
      • Place these screws on the magnetic project mat so you don't lose them.
      询问修复机器人
      添加评论
    3. Logitech G733 Power Button Replacement: 步骤 3 中的图像 1,3 Logitech G733 Power Button Replacement: 步骤 3 中的图像 2,3 Logitech G733 Power Button Replacement: 步骤 3 中的图像 3,3
      • Gently lift off the speaker housing, with care not to strain the connected cable.
      • Remove the screw on the bottom right-hand side of the motherboard using a Phillips #000 screwdriver.
      • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
      • The scroll wheel may fly out when you pop the circuit board out.
      询问修复机器人
      添加评论
    4. Logitech G733 Power Button Replacement: 步骤 4 中的图像 1,2 Logitech G733 Power Button Replacement: 步骤 4 中的图像 2,2
      • Once the motherboard is loose, gently pull the wire out of its harness.
      • The wiring harness is glued, so be careful with it. It should pull out easily.
      询问修复机器人
      添加评论
    5. Logitech G733 Power Button Replacement: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      Halberd Spudger
      $2.99
      • Pop the power button out of its recess by pushing it through the side of the headphone with your finger.
      • Now use the hook end of the halberd spudger to pry the connecting piece of the power button off at the end furthest to the inside of the headphone.
      • This step is the most difficult, so be careful when prying.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 57
总计 2,634
