简介
If your battery will no longer accept a charge and you need to replace the battery, you can do so with this guide. For this guide, you will need a T4 Torx screwdriver and a spudger. This is a popular repair and it is very easy to do!
你所需要的
Gently pull the right ear pad off, starting from the top.
Slide your finger around the edges until it releases completely.
Remove the ear pad.
To reassemble your device, please follow these instructions in reverse order.
6等其他人完成本指南。
5指南评论
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
Darbii Rue - 回复 分享
I fully agree
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
took 2 mins to find battery info ..........................
Logi 533-000181
after a quick search i bought this and it fit:
https://he.aliexpress.com/item/100500538...
Jad Ghanayem - 回复 分享
