跳转到主内容
加入维修社区 - 创建账户
Logitech G700s Side Button Array Replacement
你所需要的
  1. Logitech G700s Side Button Array Replacement, Top Case Replacement: 步骤 1 中的图像 1,1
    • Remove the batteries from the mouse.
    • Use a plastic opening tool to peel up the four mouse feet.
    询问修复机器人
    添加评论
  2. Logitech G700s Side Button Array Replacement: 步骤 2 中的图像 1,2 Logitech G700s Side Button Array Replacement: 步骤 2 中的图像 2,2
    • Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
    询问修复机器人
    添加评论
  3. Logitech G700s Side Button Array Replacement: 步骤 3 中的图像 1,3 Logitech G700s Side Button Array Replacement: 步骤 3 中的图像 2,3 Logitech G700s Side Button Array Replacement: 步骤 3 中的图像 3,3
    • Pull the top of the mouse off of the bottom half.
    • There's a wire connecting the two halves.
    • Unplug the programmable buttons from the motherboard.
    • The white pin housing on the motherboard may come off while unplugging. In that case, use tool to pry between at location indicated to separate them and insert the housing back onto the motherboard.
    添加评论
  4. Logitech G700s Side Button Array Replacement, Programmable Side Buttons: 步骤 4 中的图像 1,3 Logitech G700s Side Button Array Replacement, Programmable Side Buttons: 步骤 4 中的图像 2,3 Logitech G700s Side Button Array Replacement, Programmable Side Buttons: 步骤 4 中的图像 3,3
    • Remove the three 5.5mm Phillips #00 screws holding the button assembly to the mouse.
    • Do not remove any of the screws on the circuit board, only the ones holding the plastic assembly in place
    询问修复机器人
    添加评论
  5. Logitech G700s Side Button Array Replacement: 步骤 5 中的图像 1,3 Logitech G700s Side Button Array Replacement: 步骤 5 中的图像 2,3 Logitech G700s Side Button Array Replacement: 步骤 5 中的图像 3,3
    • To remove the side button assembly:
    • First, unhook the cables from the cable guide so it won't get caught while popping the assembly out
    • The assembly is held in by some clip-in action from the screw posts on the top shell and screw holes on the assembly. The next step will explain in detail how to pop it out.
    • Definitely don't pull on the cable to remove like shown in the first picture. The wires are kind of frail.
    询问修复机器人
    添加评论
  6. Logitech G700s Side Button Array Replacement: 步骤 6 中的图像 1,3 Logitech G700s Side Button Array Replacement: 步骤 6 中的图像 2,3 Logitech G700s Side Button Array Replacement: 步骤 6 中的图像 3,3
    • The screw hole near the left and button side seems to be easier to pop out first. Use thumbnail to pry under the marked location while simultaneously pushing on G7 to pop it out.
    • Repeat on the other side, pressing on G8.
    • The assembly should come loose. Push on the buttons and gently wiggle and pull it out.
    • There will still be a bit of friction between the PCB and the center post on the top shell but it won't take too much force. Try to gently persuade it out.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team S2-G3, Nance Spring 2018 USF Tampa, Team S2-G3, Nance Spring 2018 的会员
USFT-NANCE-S18S2G3
4 名成员
创作了15篇指南
4指南评论
Greetings, Is the quad side button assembly still avail. for replacement?
Doesn't appear when checking the parts item for this replacement build.
Thanks.
C McDonald - 回复 分享
Would like to know about side button assembly availability also.
derekod18 - 回复 分享
Thanks for the instructions.
But If the quad button assembly can not be ordered, doesn't show up for parts, this makes this repair nearly impossible.
C McDonald - 回复 分享
Three out of the four side buttons on my G700 died a while ago. I found a replacement board online for 10€, but I wasn't ready to spend that yet. Instead, I followed the teardown guide and put the PCB in the oven at 200°C for about 8 minutes. It worked nicely and all buttons are back to life!
​If this doesn't work for you, you can always buy cheap replacement switches and solder them manually. But as my case shows, sometimes the switches are fine and the solder joints just need a quick "reflow" to bridge the connection again.
vesylkin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 58
总计 4,314
