跳转到主内容
加入维修社区 - 创建账户
Logitech G700s Scroll Wheel Replacement
你所需要的
  1. Logitech G700s Scroll Wheel Replacement, Top Case Replacement: 步骤 1 中的图像 1,1
    • Remove the batteries from the mouse.
    • Use a plastic opening tool to peel up the four mouse feet.
    询问修复机器人
    添加评论
  2. Logitech G700s Scroll Wheel Replacement: 步骤 2 中的图像 1,2 Logitech G700s Scroll Wheel Replacement: 步骤 2 中的图像 2,2
    • Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
    询问修复机器人
    添加评论
  3. Logitech G700s Scroll Wheel Replacement: 步骤 3 中的图像 1,3 Logitech G700s Scroll Wheel Replacement: 步骤 3 中的图像 2,3 Logitech G700s Scroll Wheel Replacement: 步骤 3 中的图像 3,3
    • Pull the top of the mouse off of the bottom half.
    • There's a wire connecting the two halves.
    • Unplug the programmable buttons from the motherboard.
    • The white pin housing on the motherboard may come off while unplugging. In that case, use tool to pry between at location indicated to separate them and insert the housing back onto the motherboard.
    添加评论
  4. Logitech G700s Scroll Wheel Replacement, Scroll Wheel: 步骤 4 中的图像 1,3 Logitech G700s Scroll Wheel Replacement, Scroll Wheel: 步骤 4 中的图像 2,3 Logitech G700s Scroll Wheel Replacement, Scroll Wheel: 步骤 4 中的图像 3,3
    • Remove the black pin that holds the scroll wheel to the motherboard.
    • The protrusion on the bottom side of the pin clicks into the dimple on the base.
    • I find the easiest way to remove the pin is to use the pointy end of the spudger to push on this end of the pin.
    询问修复机器人
    添加评论
  5. Logitech G700s Scroll Wheel Replacement: 步骤 5 中的图像 1,3 Logitech G700s Scroll Wheel Replacement: 步骤 5 中的图像 2,3 Logitech G700s Scroll Wheel Replacement: 步骤 5 中的图像 3,3
    • First, lift the assembly from the back (green arrow), while keeping the front clear plastic part resting on the springs (red circle).
    • Then, while pulling it toward the back very slightly, carefully lift the front part off the springs.
    • It might jump a little bit from the springs.
    • The clear front part has a hole that attaches onto a clear nibble just below the bracket (blue arrow in second picture) for the scrollwheel to pivot left and right for the left and right scroll function.
    • Though the pivot point isn't attached too deeply. When reassembling, align the circular marks in the front to the springs, then press the back side down into the holder and it will self align.
    • Be careful not to lose the two small springs! They are magnetic and could attach to any magnetic tip screw driver!
    • Leaving a magnet on the metal clip might help to retain the springs, though I haven't tried it.
    • Remove the springs and keep them safe.
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team S2-G3, Nance Spring 2018 USF Tampa, Team S2-G3, Nance Spring 2018 的会员
USFT-NANCE-S18S2G3
4 名成员
创作了15篇指南
1指南评论
Very good guide! The replacement scroll wheel I got on eBay did not have the black plastic part that sits on top, so I had to remove it from the original one. I did that by pulling the clear plastic part away slightly and removing it (do one side first and then the other side).
Ash - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 64
总计 7,740
