你所需要的
If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
7等其他人完成本指南。
9指南评论
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
