跳转到主内容
加入维修社区 - 创建账户
Logitech G502 Lightspeed Switches Replacement
你所需要的
  1. Logitech G502 Lightspeed Switches Replacement, Remove skates: 步骤 1 中的图像 1,1
    • First off, remove the magnetic cover and remove the 3 stock skates. You can reuse them if you pull them off carefully. Logitech skates consist of the actual Teflon skates and a second layer of foamy adhesive. Make sure you pull off both still attached to each other.
    添加评论
  2. Logitech G502 Lightspeed Switches Replacement, Remove screws: 步骤 2 中的图像 1,1
    • Remove the 4 screws.
    询问修复机器人
    添加评论
  3. Logitech G502 Lightspeed Switches Replacement, Open cover: 步骤 3 中的图像 1,1
    • Start at the back and just clip the whole cover open. Don't be afraid to use a little force. Either use a clipping tool, or just use 3 fingers and your fingernails to grab into the gap and pull it off.
    询问修复机器人
    添加评论
  4. Logitech G502 Lightspeed Switches Replacement, Detach cables: 步骤 4 中的图像 1,1
    • Detach both flat cables and the battery connector.
    添加评论
  5. Logitech G502 Lightspeed Switches Replacement, Remove screws: 步骤 5 中的图像 1,1
    • Remove these 8 screws.
    添加评论
  6. Logitech G502 Lightspeed Switches Replacement: 步骤 6 中的图像 1,2 Logitech G502 Lightspeed Switches Replacement: 步骤 6 中的图像 2,2
    • Next remove this screw (it's hidden deep, you will need a thin screwdriver to reach it)
    • And this one, This will allow you to remove the top LED cover.
    添加评论
  7. Logitech G502 Lightspeed Switches Replacement, Remove LED cover: 步骤 7 中的图像 1,1
    • Remove the LED cover and remove this screw to remove the LED cup.
    添加评论
  8. Logitech G502 Lightspeed Switches Replacement, Remove screws: 步骤 8 中的图像 1,1
    • Remove these 4 screws which attach the 2 main buttons to the rest of the module. The right mouse button will fall out, while the left one will stay in place, just put the right one aside for now, you can leave the left one hanging loose. After removing these 4 screws, just pull out the whole internal module.
    添加评论
  9. Logitech G502 Lightspeed Switches Replacement, Remove buttons: 步骤 9 中的图像 1,3 Logitech G502 Lightspeed Switches Replacement, Remove buttons: 步骤 9 中的图像 2,3 Logitech G502 Lightspeed Switches Replacement, Remove buttons: 步骤 9 中的图像 3,3
    • Remove these 2 screws and remove the 2 top button pieces.
    询问修复机器人
    添加评论
  10. Logitech G502 Lightspeed Switches Replacement: 步骤 10 中的图像 1,3 Logitech G502 Lightspeed Switches Replacement: 步骤 10 中的图像 2,3 Logitech G502 Lightspeed Switches Replacement: 步骤 10 中的图像 3,3
    • Pull out this plastic bolt which holds the scroll wheel module in place. I suggest you use something sharp to push at the bolt from the one end and pull it with your fingernails from the other side at the same time. It will require some force. After it's out, you can simply lift the whole scroll wheel module off the PCB.
    • When lifting the scroll wheel module, make sure you do not lose the 2 springs!
    添加评论
  11. Logitech G502 Lightspeed Switches Replacement, Remove screws: 步骤 11 中的图像 1,1
    • Remove these 2 screws and remove the scroll wheel holder.
    询问修复机器人
    添加评论
  12. Logitech G502 Lightspeed Switches Replacement, Remove screws: 步骤 12 中的图像 1,1
    • Remove these 5 screws.
    询问修复机器人
    添加评论
  13. Logitech G502 Lightspeed Switches Replacement, Solder off switches: 步骤 13 中的图像 1,3 Logitech G502 Lightspeed Switches Replacement, Solder off switches: 步骤 13 中的图像 2,3 Logitech G502 Lightspeed Switches Replacement, Solder off switches: 步骤 13 中的图像 3,3
    • Solder off the Omrons and replace them with switches of your choice.
    添加评论
  14. Logitech G502 Lightspeed Switches Replacement, Put everything back together: 步骤 14 中的图像 1,1
    • Put everything back together.
    添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
einself
于01/08/17注册
635 声望
撰写一个指南
6指南评论
Thanks for the guide, i used some isopropanol to clean the switches instead of chaning them as i had a problem with the right one and now it works flawless.
Bass pojken XD - 回复 分享
Thank you for the guide! I had to replace both my left mouse button and right mouse button switches because of heavy use. I unfortunately de-soldered a bit too hard on my right button switch and had to replace some trace connections but the mouse is working great now! Much appreciated!
Yashin lalji - 回复 分享
Thanks so much for the guide; my middle mouse button was no longer giving tactile feedback when I pressed the center wheel. I ended up removing the tactile dome (just the dome and tape) and using one from my old 2011 Ford F-150 key fob works like new.
Mike Morrison - 回复 分享
i was able to fix mine by taking it out and flexing it back the right way with a little force, seems to pop back good as new for now
Slushie - 回复 分享
thanks for the guide!
Slushie - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 32
过去 7 天: 316
过去 30 天: 1,277
总计 22,610
