跳转到主内容
Logitech G502 Lightspeed Battery Replacement
你所需要的
  1. Logitech G502 Lightspeed Battery Replacement, Switch the mouse off: 步骤 1 中的图像 1,2 Logitech G502 Lightspeed Battery Replacement, Switch the mouse off: 步骤 1 中的图像 2,2
    • Before you begin, flip the power switch into the OFF position.
  2. Logitech G502 Lightspeed Battery Replacement, Heat the mouse feet: 步骤 2 中的图像 1,2 Logitech G502 Lightspeed Battery Replacement, Heat the mouse feet: 步骤 2 中的图像 2,2
    • Heat an iOpener and apply it to the mouse feet for one minute.
    • You may use a hair dryer or heat gun. If you do, set it to the lowest temperature setting and apply heat for 10 seconds.
  3. Logitech G502 Lightspeed Battery Replacement, Remove the front foot: 步骤 3 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Remove the front foot: 步骤 3 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Remove the front foot: 步骤 3 中的图像 3,3
    • Insert the tip of an opening pick underneath the front foot at the gap in its recess.
    • The mouse feet are made of two layers. Make sure you insert the pick under the bottom layer to completely remove the foot.
    • When possible, grab with your fingers and slowly pull to peel it off completely.
  4. Logitech G502 Lightspeed Battery Replacement, Remove the front right foot: 步骤 4 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Remove the front right foot: 步骤 4 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Remove the front right foot: 步骤 4 中的图像 3,3
    • Insert the tip of an opening pick underneath the tiny front right foot at the gap in its recess.
  5. Logitech G502 Lightspeed Battery Replacement, Remove the rear foot: 步骤 5 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Remove the rear foot: 步骤 5 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Remove the rear foot: 步骤 5 中的图像 3,3
    • Insert the tip of an opening pick underneath the rear foot starting at the gap in its recess.
    • When installing a new foot:
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  6. Logitech G502 Lightspeed Battery Replacement, Remove the weight hatch: 步骤 6 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Remove the weight hatch: 步骤 6 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Remove the weight hatch: 步骤 6 中的图像 3,3
    • Use your fingers to remove the weight hatch by pulling the bottom part of the thumb rest straight down.
  7. Logitech G502 Lightspeed Battery Replacement, Remove the bottom screws: 步骤 7 中的图像 1,2 Logitech G502 Lightspeed Battery Replacement, Remove the bottom screws: 步骤 7 中的图像 2,2
    • Remove the four 5.4 mm long Phillips screws at the underside of the mouse.
  8. Logitech G502 Lightspeed Battery Replacement, Unclip the bottom plate: 步骤 8 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Unclip the bottom plate: 步骤 8 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Unclip the bottom plate: 步骤 8 中的图像 3,3
    • Insert an opening pick between the bottom plate and the upper shell starting at the rear of the mouse.
    • Slide the opening pick along the gap between the two halves towards the outer flank of the mouse.
    • Twist the opening pick to disengage the clips holding both halves together.
    • This might require more force than anticipated.
  9. Logitech G502 Lightspeed Battery Replacement: 步骤 9 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement: 步骤 9 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement: 步骤 9 中的图像 3,3
    • Again insert the tip of an opening pick between the bottom plate and the top shell starting at the rear.
    • Slide the pick along the gap between the two halves towards the thumb rest.
    • Make sure to follow the curved geometry to keep the pick in the gap.
    • Twist the opening pick to unhinge the remaining clips.
    • This also might require more force than anticipated.
  10. Logitech G502 Lightspeed Battery Replacement, Hinge open the top shell: 步骤 10 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Hinge open the top shell: 步骤 10 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Hinge open the top shell: 步骤 10 中的图像 3,3
    • Flip the mouse over on its (removed) feet and hinge the top shell open towards the right side.
    • Don’t remove the top shell all the way yet. It is still connected to the bottom plate via cables.
  11. Logitech G502 Lightspeed Battery Replacement, Disconnect the battery: 步骤 11 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Disconnect the battery: 步骤 11 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Disconnect the battery: 步骤 11 中的图像 3,3
    • Hold the battery cable close to the connector and carefully "walk it out" by pulling parallel to the motherboard rocking the connector side to side.
    • Grip the cable as close to the head as possible to avoid damaging the socket.
    • You can also use a pair of angled tweezers to grip the connector head and pull it straight out of its socket.
    • If you're having trouble, insert the points of your tweezers into the small rectangular holes on top of the socket and push the connector out.
  12. Logitech G502 Lightspeed Battery Replacement, Disconnect the interconnect cables: 步骤 12 中的图像 1,3 Logitech G502 Lightspeed Battery Replacement, Disconnect the interconnect cables: 步骤 12 中的图像 2,3 Logitech G502 Lightspeed Battery Replacement, Disconnect the interconnect cables: 步骤 12 中的图像 3,3
    • Use a spudger or your fingernail to flip up the small, hinged locking flap of both ZIF connectors to disconnect and free the interconnect cables.
    • If the cables don’t pop out by themselves use your fingers to lift them out of the sockets.
  13. Logitech G502 Lightspeed Battery Replacement, Loosen the battery: 步骤 13 中的图像 1,2 Logitech G502 Lightspeed Battery Replacement, Loosen the battery: 步骤 13 中的图像 2,2
    • Insert the tip of an opening pick between the battery and its plastic tub.
    • Use an opening pick to pry the battery up slightly to loosen the adhesive underneath.
  14. Logitech G502 Lightspeed Battery Replacement, Get underneath the battery: 步骤 14 中的图像 1,2 Logitech G502 Lightspeed Battery Replacement, Get underneath the battery: 步骤 14 中的图像 2,2
    • Push the opening pick all the way under the battery.
  15. Logitech G502 Lightspeed Battery Replacement, Remove the battery: 步骤 15 中的图像 1,2 Logitech G502 Lightspeed Battery Replacement, Remove the battery: 步骤 15 中的图像 2,2
    • The battery adhesive will now stick mostly to the opening pick.
    • Slowly pull the opening pick towards the rear of the mouse to slide the battery out from under the plastic tab and out of its tub.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape if the battery comes without one. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
28等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
129,223 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
8指南评论
What type of battery is needed as replacement?
Jonas - 回复
The battery model is "AHB521630"
Tobias Isakeit -
Very good tutorial !
If you are searching a new battery, Aliexpress is your friend :)
zhorglub - 回复
Thank u for the Instruction, has take less than 10 Min
Kai Petersen - 回复
A really easy and useful fix. In my experience, step 12 was unnecessary. It is easy to lay both sides down and remove the battery while they are still connected.
Danny Culling - 回复
添加评论
浏览统计数据:
过去 24 小时: 40
过去 7 天: 341
过去 30 天: 1,530
总计 54,716
