简介
By using this detailed guide, you can learn how to replace the Logitech G305 scroll wheel in 7 easy steps. Replacing a scroll wheel in a mouse is not as simple as it sounds, and takes a couple of tools to get the job done.
These tools are a crucial part of the process, and help to get it done. This repair is an essential part of larger mouse up-keep, and it helps to make sure the scroll wheel is working as it was meant to. By using this guide, you will understand how to successfully replace the scroll wheel for your Logitech G305 mouse using the tools below.
你所需要的
在这个步骤中使用的工具:Flathead 1.5 mm Screwdriver$1.99
Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
10等其他人完成本指南。
