跳转到主内容
加入维修社区 - 创建账户
Logitech G27 Shifter Potentiometer Replacement
你所需要的
  1. Logitech G27 Shifter Potentiometer Replacement, Shifter Potentiometer: 步骤 1 中的图像 1,1
    • Remove the six 9.0mm allen screws with a 2.5mm hex key.
    询问修复机器人
    添加评论
  2. Logitech G27 Shifter Potentiometer Replacement: 步骤 2 中的图像 1,1
    • Either use the plastic opening tools or a flat screwdriver to pry and pop off the cap on the shifter.
    询问修复机器人
    添加评论
  3. Logitech G27 Shifter Potentiometer Replacement: 步骤 3 中的图像 1,2 Logitech G27 Shifter Potentiometer Replacement: 步骤 3 中的图像 2,2
    • Remove the black 12.3mm screw inside the shifter with a Phillips #1 screwdriver.
    • After, remove the shifter top and shifter boot cover by pulling straight up.
    • Remove the three 15.6mm screws with a Phillips #1 screwdriver.
    添加评论
  4. Logitech G27 Shifter Potentiometer Replacement: 步骤 4 中的图像 1,1
    • Flip the device over and four 15.6mm screws with a Phillips #1 screwdriver.
    • Pull the lower clamp up and out of the shifter assembly.
    添加评论
  5. Logitech G27 Shifter Potentiometer Replacement: 步骤 5 中的图像 1,3 Logitech G27 Shifter Potentiometer Replacement: 步骤 5 中的图像 2,3 Logitech G27 Shifter Potentiometer Replacement: 步骤 5 中的图像 3,3
    • Remove the two 10mmm hex nuts with a 10mm socket and a ratchet.
    • Next, unscrew the clamps by holding the lower portion of the shifter and unscrewing the top part.
    • Also remove the nut on the screw if it wasn't removed with the lower clamp.
    询问修复机器人
    添加评论
  6. Logitech G27 Shifter Potentiometer Replacement: 步骤 6 中的图像 1,1
    • Remove the eight black 11.9mm screws from the bottom housing with a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  7. Logitech G27 Shifter Potentiometer Replacement: 步骤 7 中的图像 1,2 Logitech G27 Shifter Potentiometer Replacement: 步骤 7 中的图像 2,2
    • Carefully lift the top half of the housing from the bottom.
    • Watch out, there are 2 wires attached to the PCB board. Be careful not to damage these in any way.
    添加评论
  8. Logitech G27 Shifter Potentiometer Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the two plastic connectors with a plastic opening tool or your hands.
    询问修复机器人
    添加评论
  9. Logitech G27 Shifter Potentiometer Replacement: 步骤 9 中的图像 1,1
    • Go to the lower portion of the shifter; remove two black screws and four silver 15.9mm screws with a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  10. Logitech G27 Shifter Potentiometer Replacement: 步骤 10 中的图像 1,2 Logitech G27 Shifter Potentiometer Replacement: 步骤 10 中的图像 2,2
    • There is grease covering the whole shifting assembly so it will get messy when removing.
    • Squeeze the two metal plates together and slowly pull up. The assembly is spring loaded and will fall apart if it is not squeezed.
    询问修复机器人
    添加评论
  11. Logitech G27 Shifter Potentiometer Replacement: 步骤 11 中的图像 1,2 Logitech G27 Shifter Potentiometer Replacement: 步骤 11 中的图像 2,2
    • Remove the shifter assembly and place it on a flat surface. Then remove the metal plate with the spring and ball bearing attached.
    • This is the hardest part of reassembling. Make sure to properly place the spring inside of the inner housing and the ball bearing on top. Place the other metal piece on top of it.
    询问修复机器人
    添加评论
  12. Logitech G27 Shifter Potentiometer Replacement: 步骤 12 中的图像 1,3 Logitech G27 Shifter Potentiometer Replacement: 步骤 12 中的图像 2,3 Logitech G27 Shifter Potentiometer Replacement: 步骤 12 中的图像 3,3
    • You will now have access to the two potentiometers on the sides of the assembly. Make sure they are properly connected and if need be, replace them by removing.
    添加评论
结论
取消:我没有完成这个指南。
20等其他人完成本指南。
团队
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G4
4 名成员
创作了25篇指南
16指南评论
Where can I buy replacement pots?
Riccardo Flask - 回复 分享
Great guide, thanks a lot for the effort. It turned out that one of the cables connecting the pot to the pcb had snapped. Just going to test now.....fingers crossed. :-)
Cheers. Andy M.
Andy Mitchell - 回复 分享
Hey did It work?
Levente Gergely - 回复 分享
I didn't even have to replace them. Only cleaning with electronic cleaning spray and move the pots fully was enough to fix it. However, and I think that was the real problem, one of the pots was damaged because the plastic pointer it has to be inplace in the assembly was broken. Only one half was in place. I used something here we call "type cleaner clay", some sort of clay not use to play but to fix things to the wall or clenaning old typewriters. Comonly blue. Other forums says damaged pots are not common, only dirty or may be, as mine broken. Easy to fix
Ricker Silva - 回复 分享
Has anybody found a source for these pots? I'm guessing they're proprietary? Possibly some version of CTS 252 series? Anything they can be replaced with? I've worked on a couple of these where people opened up the shifter pots trying to clean them and damaged them, and I cannot for the life of me find any replacements and I've searched high and low through every joystick potentiometer source I could find.
David Riley - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 78
过去 30 天: 324
总计 68,947
