跳转到主内容
加入维修社区 - 创建账户
Logitech G27 C-Clamp Replacement
你所需要的
  1. Logitech G27 C-Clamp  Replacement, Steering Wheel: 步骤 1 中的图像 1,1
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    添加评论
  2. Logitech G27 C-Clamp  Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    添加评论
  3. Logitech G27 C-Clamp  Replacement: 步骤 3 中的图像 1,1
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  4. Logitech G27 C-Clamp  Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the PCB board from the wheel hub.
    询问修复机器人
    添加评论
  5. Logitech G27 C-Clamp  Replacement: 步骤 5 中的图像 1,1
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    添加评论
  6. Logitech G27 C-Clamp  Replacement: 步骤 6 中的图像 1,1
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    询问修复机器人
    添加评论
  7. Logitech G27 C-Clamp  Replacement: 步骤 7 中的图像 1,1
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  8. Logitech G27 C-Clamp  Replacement: 步骤 8 中的图像 1,1
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    添加评论
  9. Logitech G27 C-Clamp  Replacement: 步骤 9 中的图像 1,1
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    添加评论
  10. Logitech G27 C-Clamp  Replacement: 步骤 10 中的图像 1,1
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    添加评论
  11. Logitech G27 C-Clamp  Replacement: 步骤 11 中的图像 1,1
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    询问修复机器人
    添加评论
  12. Logitech G27 C-Clamp  Replacement: 步骤 12 中的图像 1,1
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  13. Logitech G27 C-Clamp  Replacement: 步骤 13 中的图像 1,2 Logitech G27 C-Clamp  Replacement: 步骤 13 中的图像 2,2
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    询问修复机器人
    添加评论
  14. Logitech G27 C-Clamp  Replacement, C-Clamp: 步骤 14 中的图像 1,1
    • Unscrew the piece holding the C-Clamp in place with your hand.
    询问修复机器人
    添加评论
  15. Logitech G27 C-Clamp  Replacement: 步骤 15 中的图像 1,2 Logitech G27 C-Clamp  Replacement: 步骤 15 中的图像 2,2
    • Push the remaining nob forward and then inward through the slot.
    询问修复机器人
    添加评论
  16. Logitech G27 C-Clamp  Replacement: 步骤 16 中的图像 1,2 Logitech G27 C-Clamp  Replacement: 步骤 16 中的图像 2,2
    • The C-Clamp can now be easily pulled out of the bottom of the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
24等其他人完成本指南。
团队
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G4
4 名成员
创作了25篇指南
15指南评论
Where would I buy the replacement C-Clamps from because one of mine are broken and I need to install a new one.
Mumin Mazhar - 回复 分享
Look for it at eBay.
Eduardo - 回复 分享
I also need to find a place to buy replacement C-clamps from
hockeyjockone - 回复 分享
Can you tell me where I can buy these clamps?
kholiwen - 回复 分享
step 9 to 13 not needed ... please confirm
Matt Na - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 126
总计 50,372
