跳转到主内容
加入维修社区 - 创建账户
Logitech G Cloud L2-R2 Trigger Replacement
你所需要的
  1. Logitech G Cloud L2-R2 Trigger Replacement, Case: 步骤 1 中的图像 1,2 Logitech G Cloud L2-R2 Trigger Replacement, Case: 步骤 1 中的图像 2,2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    添加评论
  2. Logitech G Cloud L2-R2 Trigger Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    询问修复机器人
    添加评论
  3. Logitech G Cloud L2-R2 Trigger Replacement: 步骤 3 中的图像 1,2 Logitech G Cloud L2-R2 Trigger Replacement: 步骤 3 中的图像 2,2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    询问修复机器人
    添加评论
  4. Logitech G Cloud L2-R2 Trigger Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    询问修复机器人
    添加评论
  5. Logitech G Cloud L2-R2 Trigger Replacement: 步骤 5 中的图像 1,2 Logitech G Cloud L2-R2 Trigger Replacement: 步骤 5 中的图像 2,2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    添加评论
  6. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: 步骤 6 中的图像 1,2 Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: 步骤 6 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the L2 and R2 triggers.
    • Pop the L2 and R2 triggers out with your fingers.
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 73
总计 621
