跳转到主内容
加入维修社区 - 创建账户
Logitech G Cloud Battery Replacement
你所需要的
  1. Logitech G Cloud Battery Replacement, Case: 步骤 1 中的图像 1,2 Logitech G Cloud Battery Replacement, Case: 步骤 1 中的图像 2,2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
  2. Logitech G Cloud Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
  3. Logitech G Cloud Battery Replacement: 步骤 3 中的图像 1,2 Logitech G Cloud Battery Replacement: 步骤 3 中的图像 2,2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
  4. Logitech G Cloud Battery Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
  5. Logitech G Cloud Battery Replacement: 步骤 5 中的图像 1,2 Logitech G Cloud Battery Replacement: 步骤 5 中的图像 2,2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
  6. Logitech G Cloud Battery Replacement, Battery: 步骤 6 中的图像 1,3 Logitech G Cloud Battery Replacement, Battery: 步骤 6 中的图像 2,3 Logitech G Cloud Battery Replacement, Battery: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $8.95
    • Insert the flat end of a spudger under the edge of the battery press connector and lift straight up to disconnect it.
    • Insert an opening tool under the bottom edge of the battery. Gently and slowly lift straight up to separate the adhesive on the battery from the console.
    • Take care not to bend, warp, or puncture the battery.
    • If your replacement battery doesn't come with adhesive, use a strong double-sided adhesive to secure it.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 46
总计 544
