跳转到主内容
加入维修社区 - 创建账户
Logitech Cube Mouse Battery Replacement
你所需要的
  1. Logitech Cube Mouse  Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Logitech Cube Mouse Battery Replacement/Removal
    询问修复机器人
    添加评论
  2. Logitech Cube Mouse  Battery Replacement: 步骤 2 中的图像 1,1
    • Peel the touchpad up from the support plate to make a 1 CM space.
    询问修复机器人
    添加评论
  3. Logitech Cube Mouse  Battery Replacement: 步骤 3 中的图像 1,1
    • Use a small thin object to pry outwards between the black plastic and white plastic to release two clips under the support plate.
    询问修复机器人
    添加评论
  4. Logitech Cube Mouse  Battery Replacement: 步骤 4 中的图像 1,1
    • After slowly releasing the two clips hinge up the touch panel 1 inch.
    询问修复机器人
    添加评论
  5. Logitech Cube Mouse  Battery Replacement: 步骤 5 中的图像 1,1
    • Slide the touch panel towards the back of the mouse 1CM.
    询问修复机器人
    添加评论
  6. Logitech Cube Mouse  Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the touch panel and support plate.
    询问修复机器人
    添加评论
  7. Logitech Cube Mouse  Battery Replacement: 步骤 7 中的图像 1,1
    • Lift and rotate touch panel and support plate. Disconnect the touch panel connector, the other cable helps to sense touch.
    询问修复机器人
    添加评论
  8. Logitech Cube Mouse  Battery Replacement: 步骤 8 中的图像 1,1
    • Remove battery, battery plug from board connection, metal plate, and two screws. A notch in the plate matches a groove on the inside, removal at a angle is required.
    询问修复机器人
    添加评论
  9. Logitech Cube Mouse  Battery Replacement: 步骤 9 中的图像 1,1
    • Find another battery. Original is 533-000071 3.7v 240mAh 0.63IN x 1.18IN x 0.21IN or 16.002MM X 29.972MM X 5.334MM. There is some room for different lengths and widths, but height looks to be about 5.334MM. Due to my battery's width I had to bend a tab flat on the plate and only use 1 screw.
    询问修复机器人
    添加评论
  10. Logitech Cube Mouse  Battery Replacement: 步骤 10 中的图像 1,1
    • Press the touch pad and support plate together to undo slightly peeling them apart. Attach the battery to the plate, Install plate/ battery in mouse. Plug in battery and touch panel cables, rotate touch panel and support plate back into place. Place the front tab in its slot and press the back down to attach the clips to the bar.
    询问修复机器人
    添加评论
结论
Unless the chosen battery is different, reassembly is in reverse order.
取消:我没有完成这个指南。
Brandon
于12/17/21注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 1,458
