跳转到主内容
Logic Board Connectors
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Logic Board Connectors, Disconnect the logic board: 步骤 1 中的图像 1,2 Logic Board Connectors, Disconnect the logic board: 步骤 1 中的图像 2,2
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
  2. Logic Board Connectors: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Standoff Screwdriver for iPhones
    $5.49
    购买
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. Logic Board Connectors: 步骤 3 中的图像 1,1
    • Remove the rear-facing camera bracket.
  4. Logic Board Connectors: 步骤 4 中的图像 1,2 Logic Board Connectors: 步骤 4 中的图像 2,2
    • Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
  5. Logic Board Connectors: 步骤 5 中的图像 1,1
    • Remove the two screws securing the upper cable bracket:
    • One 2.9 mm Phillips screw
    • One 1.3 mm Phillips screw
  6. Logic Board Connectors: 步骤 6 中的图像 1,1
    • Remove the upper cable bracket.
  7. Logic Board Connectors: 步骤 7 中的图像 1,2 Logic Board Connectors: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to pry the upper cable connector up from its socket.
  8. Logic Board Connectors, Remove the top left antenna component: 步骤 8 中的图像 1,1
    • Remove the three Phillips 1.3 mm screws securing the top left antenna component.
  9. Logic Board Connectors: 步骤 9 中的图像 1,1
    • Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
  10. Logic Board Connectors: 步骤 10 中的图像 1,1
    • Remove the antenna component.
  11. Logic Board Connectors, Remove the top left grounding clip: 步骤 11 中的图像 1,1
    • Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • One 1.5 mm Phillips screw
    • One 2.6 mm Phillips screw
  12. Logic Board Connectors: 步骤 12 中的图像 1,1
    • Remove the grounding clip.
  13. Logic Board Connectors, Unscrew the logic board: 步骤 13 中的图像 1,1
    • Remove the three screws securing the motherboard:
    • One 1.8 mm Phillips screw
    • One 2.5 mm standoff screw
    • One 2.2 mm standoff screw
  14. Logic Board Connectors: 步骤 14 中的图像 1,2 Logic Board Connectors: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  15. Logic Board Connectors: 步骤 15 中的图像 1,2 Logic Board Connectors: 步骤 15 中的图像 2,2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
结论
Arthur Shi
于01/03/18注册
254,543 声望
创作了529篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,410篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 220
