跳转到主内容
加入维修社区 - 创建账户
LisaTerminal with Linux/UNIX(Mac)
你所需要的
    1. LisaTerminal with Linux/UNIX(Mac), On Linux: 步骤 1 中的图像 1,1
      • In Terminal type: sudo apt-get install screen
      • sudo screen /dev/ttyUSB0 9600
      • Press ⌃A ⇧ : (at the same time). Once you see a : prompt at the bottom of the screen type
      • exec ::: /sbin/agetty -L -n 9600 ttyUSB0 vt100
      • Press return a few times on the Lisa keyboard and the login prompt should appear.
      询问修复机器人
      添加评论
    2. LisaTerminal with Linux/UNIX(Mac), On macOS: 步骤 2 中的图像 1,1
      • Type: ls /dev/cu.*
      • Copy the result that mentions USB
      • Then type the following replacing serial with the previous result: screen /dev/serial 9600
      • Press ⌃A ⇧:
      • When the : prompt appears type
      • exec ::: /usr/libexec/getty std.9600
      询问修复机器人
      添加评论
      • Open LisaTerminal and set the settings to baud rate 9600 and set serial port to A.
      • Plug the serial cable into serial port A.
      • In MacWorks Plus and Macintosh System 6, the application Mac240 supports graphics and is generally fantastic for this type of connection.
      • Mac240 can be acquired from Macintosh Garden.
      询问修复机器人
      添加评论
    3. LisaTerminal with Linux/UNIX(Mac), Uses: 步骤 4 中的图像 1,1
      • This was done so I could use mutt for email and w3m for web browsing
      • mpg123 is great for music if your connected computer has speakers.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
LisaGuide
于12/30/18注册
1,833 声望
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 31
总计 1,045
