当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
这个步骤还没有翻译 帮忙翻译一下
Turn the circuit board over and identify which solder connection you will desolder.
The solder connections shown in red hold the right antenna port in place. There is one more attachment for this antenna on the other side of the board.
The solder connections shown in blue hold the left antenna port in place. Desolder these 4 points to remove the antenna port.
2等其他人完成本指南。
