简介
You will start by isolating the motherboard and then continue to make the suggested repairs by soldering.
你所需要的
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
Unscrew the two screws that connect the motherboard to the bottom casing.
Using a soldering iron, desolder the LED lights from the bottom of the logic board.
For help with soldering or desoldering refer to ifixit's soldering guide: 如何焊接和拆焊
Once the soldering is complete, the device should work and the LED lights should light up.
另外一个人完成了本指南。
