跳转到主内容
加入维修社区 - 创建账户
Linksys E1200 Router Power Adapter Replacement
你所需要的
    1. Linksys E1200 Router Power Adapter Replacement, Power Adapter: 步骤 1 中的图像 1,1
      • Take note of the wire labeling. Each wire has either a Stripe or Text. When lining up the wires after cutting, it is critical that you keep Stripe with Stripe, and Text with Text. Failure to do so will result in damage to the device.
      询问修复机器人
      添加评论
    2. Linksys E1200 Router Power Adapter Replacement: 步骤 2 中的图像 1,3 Linksys E1200 Router Power Adapter Replacement: 步骤 2 中的图像 2,3 Linksys E1200 Router Power Adapter Replacement: 步骤 2 中的图像 3,3
      • Begin by cutting the wire.
      • Strip the wire.
      • Seperate the two halves of each wire, and split the two with a utility knife. Don't go too far! You will need the extra space to overlay HeatShrink before the soldering is down.
      询问修复机器人
      添加评论
    3. Linksys E1200 Router Power Adapter Replacement: 步骤 3 中的图像 1,3 Linksys E1200 Router Power Adapter Replacement: 步骤 3 中的图像 2,3 Linksys E1200 Router Power Adapter Replacement: 步骤 3 中的图像 3,3
      • Twist the individual strands together to make a single pigtail.
      • Overlay with the corresponding wire (Step 1), and twist together, but not before sliding on the HeatShrink.
      询问修复机器人
      添加评论
    4. Linksys E1200 Router Power Adapter Replacement: 步骤 4 中的图像 1,3 Linksys E1200 Router Power Adapter Replacement: 步骤 4 中的图像 2,3 Linksys E1200 Router Power Adapter Replacement: 步骤 4 中的图像 3,3
      • Pull the wire seperation back far enough on at least one side to permit Heat-Shrink to slip over the wire insulation.
      • Now the soldering. Place the pre-heated iron on the wires on a heat-resistant, flame proof surface. Make sure that the Heat-Shrink is nowhere near the soldering iron.
      • Let it heat for a few sconds (copper is an excellent conductor of heat), then touch the end of the solder to the wire. If fully heated, it should flow easily into the joint.
      询问修复机器人
      添加评论
    5. Linksys E1200 Router Power Adapter Replacement: 步骤 5 中的图像 1,3 Linksys E1200 Router Power Adapter Replacement: 步骤 5 中的图像 2,3 Linksys E1200 Router Power Adapter Replacement: 步骤 5 中的图像 3,3
      • To protect the solder job, you will need to slide the shrink wrap over the patch, then heat it so that it grips the wire securely. You can use a heat gun or the flat side of a soldering iron. Be careful to not let it burn!
      • Repeat for the other wire. Repeat for the overall sheath.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Michigan Tech, Team 5-4, Lauer Spring 2014 Michigan Tech, Team 5-4, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G4
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 37
总计 3,194
