此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
转到步骤 1 ↓电机故障会严重影响你的 Levoit Core 300-RAC 空气净化器的性能。如果你的设备出风量不足,或者风扇似乎没有转动,那么可能是时候更换电机了。本指南将引导你完成更换 Levoit Core 300-RAC 空气净化器电机的过程。
在开始之前,请关闭空气净化器并从电源插座上拔下插头。
你所需要的
配件
工具
Heat Gun$29.994.7选填
This tool is only necessary if heat shrink tubing is to be used for reassembly.
要重新组装设备,请按相反顺序执行这些说明。你可以使用焊料和热缩管,或者使用接线螺母来重新连接电源线。
3等其他人完成本指南。
6指南评论
Thanks for a comprehensive teardown, and here because I'm thinking of making a new control board for the Leovit. One thing, the article seems to fall short on one crucial point though, given that it's about replacing the motor, and that's where to get a replacement and details about the motor itself. Being pedantic, it also doesn't actually describe how to replace the motor, only how to get to the stage of being able to replace it.
Hello, thanks for the instructions, do you have a photo of the production label of the fan please? I can't read it. Thank you. John
Jan Nedbal - 回复 分享
Thank you for your instructions. Our Levoit 300 is making a high pitched sound. I've read on other sites to grease the bearings. Could you please explain how I can find the bearings and what they look like?
Thank you
