跳转到主内容
Lenovo Yoga 6 13ALC6 Battery Replacement
你所需要的
  1. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: 步骤 2 中的图像 1,2 Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: 步骤 3 中的图像 1,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: 步骤 3 中的图像 2,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: 步骤 4 中的图像 1,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: 步骤 4 中的图像 2,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: 步骤 4 中的图像 3,3
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Battery Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga 6 13ALC6 Battery Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga 6 13ALC6 Battery Replacement: 步骤 5 中的图像 3,3
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Battery Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 6 13ALC6 Battery Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 6 13ALC6 Battery Replacement: 步骤 6 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: 步骤 7 中的图像 1,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: 步骤 7 中的图像 2,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: 步骤 7 中的图像 3,3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: 步骤 8 中的图像 1,2 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  9. Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: 步骤 9 中的图像 1,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: 步骤 9 中的图像 2,3 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: 步骤 9 中的图像 3,3
    • Lift the battery straight out of its recess and remove it.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
124,885 声望
创作了582篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,392篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 30
过去 30 天: 157
总计 2,021
