简介
Follow this guide to replace or remove the battery in your Lenovo YOGA 730-15IKB. The battery powers the computer when the charger is not plugged in. It is a wise idea to unplug the battery before touching any component inside the computer to avoid hurting the laptop or yourself.
If your computer is running out of battery quickly or will not power on when it is not plugged in, you might need to replace your battery. See the troubleshooting page for more advice.
你所需要的
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8等其他人完成本指南。
