跳转到主内容
Lenovo ThinkPad X395 Battery Replacement
你所需要的
  1. Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: 步骤 1 中的图像 1,2 Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These are captive screws—they won't come out after being loosened.
  2. Lenovo ThinkPad X395 Battery Replacement, Release the clips: 步骤 2 中的图像 1,2 Lenovo ThinkPad X395 Battery Replacement, Release the clips: 步骤 2 中的图像 2,2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad X395 Battery Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad X395 Battery Replacement: 步骤 3 中的图像 2,2
    • Insert the opening pick between the back cover and the device body at the other hinge corner.
    • Pry upward on the cover to release additional clips.
  4. Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: 步骤 4 中的图像 1,3 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: 步骤 4 中的图像 2,3 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Lift and remove the cover up from the laptop, starting with the edge nearest to you.
    • Shift the cover side to side if the center clip feels stuck.
    • The cover will hinge open before completely separating from the rest of the laptop.
  5. Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: 步骤 5 中的图像 1,2 Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: 步骤 5 中的图像 2,2
    • Grab the battery pull-tab on the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad X395 Battery Replacement, Unfasten the battery: 步骤 6 中的图像 1,1
    • Use your Phillips screwdriver to remove the four 5.3 mm-long screws securing the battery.
  7. Lenovo ThinkPad X395 Battery Replacement, Remove the battery: 步骤 7 中的图像 1,2 Lenovo ThinkPad X395 Battery Replacement, Remove the battery: 步骤 7 中的图像 2,2
    • Remove the battery from its recess.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
于09/19/22注册
70,402 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 44
过去 30 天: 239
总计 2,768
