跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad X280 Fingerprint Scanner Replacement
你所需要的
    1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Back Panel: 步骤 1 中的图像 1,1
      • To begin, ensure that the device is completely powered off and not connected to an energy supply.
      • Close the device and flip it over to expose the back panel.
      询问修复机器人
      添加评论
    2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 步骤 2 中的图像 2,2
      • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
      • These are captive screws and do not come out completely.
      询问修复机器人
      添加评论
    3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 步骤 3 中的图像 2,2
      • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
      • Remove the back cover.
      询问修复机器人
      添加评论
    1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 步骤 4 中的图像 1,3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 步骤 4 中的图像 2,3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 步骤 4 中的图像 3,3
      • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
      • Remove the battery.
      询问修复机器人
      添加评论
    1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 步骤 5 中的图像 1,3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 步骤 5 中的图像 2,3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 步骤 5 中的图像 3,3
      • Using a Phillips #1 screwdriver, remove one 5 mm screw from the fingerprint sensor.
      • Remove the metal plate covering the sensor.
      询问修复机器人
      添加评论
    2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 步骤 6 中的图像 2,2
      • Using the black spudger tool, flip up the small hinged locking flap connected to the motherboard.
      • Gently pull the cable out of the connection site.
      询问修复机器人
      添加评论
    3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 步骤 7 中的图像 1,1
      • Remove fingerprint scanner and metal covering from device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 1,933
