跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad X140e Keyboard Replacement
你所需要的
    1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Set the laptop facing you with the screen open.
      询问修复机器人
      添加评论
    2. Lenovo ThinkPad X140e Keyboard Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X140e Keyboard Replacement: 步骤 2 中的图像 2,2
      • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
      添加评论
    3. Lenovo ThinkPad X140e Keyboard Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad X140e Keyboard Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad X140e Keyboard Replacement: 步骤 3 中的图像 3,3
      • Flip up the ZIF connector that is holding the small ribbon cable in place.
      • Proceed to pull out the small ribbon cable
      询问修复机器人
      添加评论
    4. Lenovo ThinkPad X140e Keyboard Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad X140e Keyboard Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad X140e Keyboard Replacement: 步骤 4 中的图像 3,3
      • Flip up the ZIF connector that is holding the larger ribbon cable in place.
      • Proceed to pull out the large ribbon cable.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
kevin hull
于10/05/16注册
219 声望
创作了2篇指南
团队
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G5
4 名成员
创作了45篇指南
4指南评论
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - 回复 分享
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 - 回复 分享
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - 回复 分享
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 49
总计 2,319
