跳转到主内容
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
你所需要的
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: 步骤 2 中的图像 1,1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: 步骤 3 中的图像 1,1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: 步骤 4 中的图像 1,3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: 步骤 4 中的图像 2,3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out of the frame and remove it from the device.
结论
4等其他人完成本指南。
团队
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G3
4 名成员
创作了8篇指南
2条评论
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - 回复
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 37
过去 30 天: 272
总计 11,994
