跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad T560 Back Panel Replacement
你所需要的
    1. Lenovo ThinkPad T560 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
      • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
      • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
      添加评论
    2. Lenovo ThinkPad T560 Back Panel Replacement: 步骤 2 中的图像 1,1
      • Use the iFixit opening tool to pry the back panel off your T560.
      • Work your way around the perimeter of the device to undo the clips and detach the back panel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G3
5 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 45
总计 1,747
