跳转到主内容
Lenovo ThinkPad T490s Battery Replacement
你所需要的
  1. Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: 步骤 1 中的图像 1,2 Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Battery Replacement, Release the clips: 步骤 2 中的图像 1,2 Lenovo ThinkPad T490s Battery Replacement, Release the clips: 步骤 2 中的图像 2,2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Battery Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad T490s Battery Replacement: 步骤 3 中的图像 2,2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: 步骤 4 中的图像 1,3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: 步骤 4 中的图像 2,3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: 步骤 5 中的图像 1,2 Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: 步骤 5 中的图像 2,2
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: 步骤 6 中的图像 1,2 Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: 步骤 6 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the five 5.2 mm-long screws securing the battery.
  7. Lenovo ThinkPad T490s Battery Replacement, Remove the battery: 步骤 7 中的图像 1,3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: 步骤 7 中的图像 2,3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: 步骤 7 中的图像 3,3
    • Lift the battery straight out of its recess and remove it.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
于01/16/22注册
124,540 声望
创作了581篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,289篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 79
过去 30 天: 367
总计 4,890
