跳转到主内容
Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement
你所需要的
  1. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, External Battery: 步骤 1 中的图像 2,2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Back Cover: 步骤 3 中的图像 1,2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 4 中的图像 3,3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Internal Battery: 步骤 5 中的图像 1,2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Internal Battery: 步骤 5 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 6 中的图像 3,3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 7 中的图像 3,3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
  8. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Fan Assembly/Heatsink: 步骤 8 中的图像 1,2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Fan Assembly/Heatsink: 步骤 8 中的图像 2,2
    • Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
  9. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 9 中的图像 1,2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 9 中的图像 2,2
    • Use the black nylon spudger to slide the fan connector parallel to the motherboard and out of its socket on the motherboard.
  10. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 10 中的图像 1,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 10 中的图像 2,3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: 步骤 10 中的图像 3,3
    • Lift the fan assembly off of the board.
    • Prior to replacing your fan assembly, remember to apply thermal paste.
结论
2等其他人完成本指南。
Sarah Westberg
于03/11/19注册
23,263 声望
创作了70篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,262篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 48
过去 30 天: 228
总计 4,906
