跳转到主内容
Lenovo ThinkPad T460s Battery Replacement
你所需要的
  1. Lenovo ThinkPad T460s Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Battery Replacement: 步骤 3 中的图像 1,1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Battery Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T460s Battery Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T460s Battery Replacement: 步骤 4 中的图像 3,3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
13等其他人完成本指南。
12条评论
I have a question, please. Are the two batteries identical?
Felipe L.R. - 回复
No, the batteries are different.
Battery 1 Part Number: 00HW022. (23.510 mWh)
Battery 2 Part Number: 01AV405. (26.330 mWh)
Best regards!
Rafael -
Hi there, anyone know which battery is number 1? - only battery 1 is broken in my laptop, 2 still works.
Jonas Andersen - 回复
Hello!!?? Any in iFixit knows the answer to Jonas’ question???
Ruben -
Battery 1 is 00HW022. (23.510 mWh)
Battery 2 is 01AV405. (26.330 mWh)
You can confirm it by yourself running powercfg /batteryreport on cmd
Hope it helps!
Rafael -
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 111
过去 30 天: 500
总计 49,669
