简介
Use this guide to replace the hinges in your Lenovo ThinkPad T460 laptop.
Laptop hinges that are in good condition will allow you to open the laptop lid with ease. The laptop hinges may be malfunctioning if you experience extreme stiffness or looseness when opening and closing the laptop lid. Other symptoms include the lid not shutting completely, the lid not staying open, dislocated hinges, or cracks around the hinges or in the hinges themselves.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
你所需要的
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Remove the two 3.7 mm screws from the LCD cable bracket using a Phillips #1 screwdriver.
Use your hands to peel up the thin LCD bezel sheet from the rest of the display, starting in the area between the hinges.
Use your hands to continue peeling the bezel sheet away from the left side of the laptop.
Use both hands to lift the bottom corners of the display panel
Gently flip the display panel over.
