跳转到主内容
Lenovo Miix 2 Speakers Replacement
你所需要的
  1. Lenovo Miix 2 Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo Miix 2 Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Speakers Replacement: 步骤 2 中的图像 1,2 Lenovo Miix 2 Speakers Replacement: 步骤 2 中的图像 2,2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Speakers Replacement: 步骤 3 中的图像 1,2 Lenovo Miix 2 Speakers Replacement: 步骤 3 中的图像 2,2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Speakers Replacement: 步骤 4 中的图像 1,2 Lenovo Miix 2 Speakers Replacement: 步骤 4 中的图像 2,2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Speakers Replacement, Speakers: 步骤 5 中的图像 1,2 Lenovo Miix 2 Speakers Replacement, Speakers: 步骤 5 中的图像 2,2
    • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
    • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
结论
Diana Chiu
于07/14/14注册
654 声望
创作了4篇指南
团队
Kid fixers Kid fixers 的会员
Community
157 名成员
创作了294篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 948
