跳转到主内容
Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement
你所需要的
  1. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Release the clips: 步骤 3 中的图像 1,3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Release the clips: 步骤 3 中的图像 2,3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the lower case: 步骤 4 中的图像 1,3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the lower case: 步骤 4 中的图像 2,3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the lower case: 步骤 4 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 1,3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 2,3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 3,3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  6. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Unfasten the battery: 步骤 6 中的图像 1,1
    • Use your Phillips screwdriver to remove the four 5.6 mm-long screws securing the battery.
  7. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the battery: 步骤 7 中的图像 1,2 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the battery: 步骤 7 中的图像 2,2
    • Remove the battery from its recess.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
2等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
67,432 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 70
过去 30 天: 302
总计 5,989
