跳转到主内容
Lenovo IdeaPad Flex 5-1570 Heatsink Replacement
你所需要的
  1. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 2 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 2 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 3 中的图像 2,2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: 步骤 4 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 5 中的图像 3,3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Fan: 步骤 6 中的图像 1,1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  7. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 7 中的图像 1,1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  8. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 8 中的图像 2,2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  9. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Heatsink: 步骤 9 中的图像 1,1
  10. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 10 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 步骤 10 中的图像 2,2
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
结论
Don’t forget to reapply thermal paste during reassembly. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
另外一个人完成了本指南。
Justin Ogihara
于09/18/17注册
27,662 声望
创作了52篇指南
团队
EDU Team EDU Team 的会员
Staff
7 名成员
创作了677篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 41
总计 882
