跳转到主内容
Lenovo IdeaPad 120s-14IAP Battery Replacement
你所需要的
  1. Lenovo IdeaPad 120s-14IAP Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo IdeaPad 120s-14IAP Battery Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo IdeaPad 120s-14IAP Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove five 1.5mm Phillips screws from the battery edges.
  4. Lenovo IdeaPad 120s-14IAP Battery Replacement: 步骤 4 中的图像 1,1
    • Use your fingers or a spudger to unlock the wide ribbon cable's ZIF connector.
    • To unlock a ZIF connector, flip up the small, hinged locking flap.
    • Gently pull the connector from the battery side until it is fully detached from the daughterboard.
  5. Lenovo IdeaPad 120s-14IAP Battery Replacement: 步骤 5 中的图像 1,1
    • Gently pull the power harness away from the daughterboard until the connector is detached.
    • Pull parallel to the board, not straight up.
  6. Lenovo IdeaPad 120s-14IAP Battery Replacement: 步骤 6 中的图像 1,1
    • With the laptop oriented so that the long edge faces you and the battery is closest to you, carefully remove the battery by lifting on the longitudinal edge.
    • Pull the battery directly towards you and out from under the forward retaining strap.
结论
另外一个人完成了本指南。
2条评论
Thank you for showing exactly how to remove the battery connections, thanks!
Erik Gunnar Gervin - 回复
Great guide. I may well need a new battery but would appreciate your comment. Battery shows charging but never gets above 0%
When I put a meter at the 2 red cables they show zero volts (even when computer on, and showing charging). Other wires are ~1.6v & 3.4v.
Could I have a faulty battery or something else?
Colin Kinsella - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 41
总计 5,179
