跳转到主内容
加入维修社区 - 创建账户
Lenovo Essential G570 Keyboard Replacement
你所需要的
    1. Lenovo Essential G570 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to unplug the cable could result in electric shock.
      • Turn the computer upside down.
      询问修复机器人
      添加评论
    2. Lenovo Essential G570 Keyboard Replacement: 步骤 2 中的图像 1,2 Lenovo Essential G570 Keyboard Replacement: 步骤 2 中的图像 2,2
      • Locate the two switches that lock the battery.
      • Push the right switch outwards to unlock the battery.
      询问修复机器人
      添加评论
    3. Lenovo Essential G570 Keyboard Replacement: 步骤 3 中的图像 1,2 Lenovo Essential G570 Keyboard Replacement: 步骤 3 中的图像 2,2
      • Push and hold the left switch outwards to unlock the battery.
      • Pull the battery away from the computer.
      询问修复机器人
      添加评论
    1. Lenovo Essential G570 Keyboard Replacement, Back Panel: 步骤 4 中的图像 1,1
      • Turn the laptop over so that the bottom side is facing up.
      询问修复机器人
      添加评论
    2. Lenovo Essential G570 Keyboard Replacement: 步骤 5 中的图像 1,1
      • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
      • The screws do not come out fully from the back plate. They stay attached to the plate itself.
      询问修复机器人
      添加评论
    3. Lenovo Essential G570 Keyboard Replacement: 步骤 6 中的图像 1,3 Lenovo Essential G570 Keyboard Replacement: 步骤 6 中的图像 2,3 Lenovo Essential G570 Keyboard Replacement: 步骤 6 中的图像 3,3
      • With the screws removed, insert the plastic opening tool into the groove located on the right side.
      • Begin to pry up, and the plate should lift up from the body of the laptop.
      • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
      询问修复机器人
      添加评论
    1. Lenovo Essential G570 Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,1
      • Remove the two 9mm Phillips #0 screws.
      • Remove the single 5mm Phillips #0 screw.
      • All 3 screws are located next to keyboard icons.
      询问修复机器人
      添加评论
    2. Lenovo Essential G570 Keyboard Replacement: 步骤 8 中的图像 1,2 Lenovo Essential G570 Keyboard Replacement: 步骤 8 中的图像 2,2
      • Flip the computer over and open it.
      • Using the plastic opening tool, pry open the top of the keyboard.
      询问修复机器人
      添加评论
    3. Lenovo Essential G570 Keyboard Replacement: 步骤 9 中的图像 1,1
      • Remove the keyboard by gently pulling the top of the keyboard loose, and then lifting the keyboard out.
      • Be careful lifting the keyboard up because there is a delicate ribbon cable connected to the bottom.
      询问修复机器人
      添加评论
    4. Lenovo Essential G570 Keyboard Replacement: 步骤 10 中的图像 1,3 Lenovo Essential G570 Keyboard Replacement: 步骤 10 中的图像 2,3 Lenovo Essential G570 Keyboard Replacement: 步骤 10 中的图像 3,3
      • While lifting the keyboard, push the black latch on the keyboard cable ZIF connector forward to unlock it.
      • Carefully pull away the ribbon cable to detach it from the motherboard.
      • Be careful when unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 的会员
UMASSD-SIMCOCK-S18S1G1
3 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 40
总计 3,157
