跳转到主内容
加入维修社区 - 创建账户
Lenovo Essential B570 Keyboard Replacement
你所需要的
    1. Lenovo Essential B570 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn over laptop.
      • Switch open the left battery lock.
      • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
      询问修复机器人
      添加评论
    2. Lenovo Essential B570 Keyboard Replacement: 步骤 2 中的图像 1,1
      • Hold the right battery lock open with one hand while removing the battery itself with the other.
      询问修复机器人
      添加评论
    1. Lenovo Essential B570 Keyboard Replacement, Back Panel: 步骤 3 中的图像 1,1
      • Loosen the five Philips screws that secure the panel.
      • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
      询问修复机器人
      添加评论
    2. Lenovo Essential B570 Keyboard Replacement: 步骤 4 中的图像 1,3 Lenovo Essential B570 Keyboard Replacement: 步骤 4 中的图像 2,3 Lenovo Essential B570 Keyboard Replacement: 步骤 4 中的图像 3,3
      • Prop open the cover with a plastic opening tool.
      • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
      询问修复机器人
      添加评论
    1. Lenovo Essential B570 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
      • Remove the three 3 mm Phillips screws holding the keyboard in. These screws are designated by an imprinted keyboard picture next to them.
      询问修复机器人
      添加评论
    2. Lenovo Essential B570 Keyboard Replacement: 步骤 6 中的图像 1,2 Lenovo Essential B570 Keyboard Replacement: 步骤 6 中的图像 2,2
      • Carefully pry off the keyboard with your plastic opening tool , moving along the edges.
      • DO NOT immediately remove the keyboard as it is still connected underneath by a wire.
      询问修复机器人
      添加评论
    3. Lenovo Essential B570 Keyboard Replacement: 步骤 7 中的图像 1,2 Lenovo Essential B570 Keyboard Replacement: 步骤 7 中的图像 2,2
      • Carefully lift the keyboard.
      • The keyboard is still connected to the laptop. Lift it slowly.
      • Turn over the keyboard to locate the keyboards ribbon cable.
      询问修复机器人
      添加评论
    4. Lenovo Essential B570 Keyboard Replacement: 步骤 8 中的图像 1,2 Lenovo Essential B570 Keyboard Replacement: 步骤 8 中的图像 2,2
      • Use the plastic opening tool to lift open the ribbon connector that is holding the ribbon cable in its slot.
      询问修复机器人
      添加评论
    5. Lenovo Essential B570 Keyboard Replacement: 步骤 9 中的图像 1,2 Lenovo Essential B570 Keyboard Replacement: 步骤 9 中的图像 2,2
      • Remove the cable from its slot.
      • If the cable does not come out easily, ensure that the black ribbon has been completely released.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G5
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 3,132
