跳转到主内容
加入维修社区 - 创建账户
Lenovo Edge 15 LCD Screen Replacement
你所需要的
    1. Lenovo Edge 15 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
      • Remove the black plastic or rubber screw caps covering screws, located at the bottom of the screen
      添加评论
    2. Lenovo Edge 15 LCD Screen Replacement: 步骤 2 中的图像 1,2 Lenovo Edge 15 LCD Screen Replacement: 步骤 2 中的图像 2,2
      • Remove the (2) M2.5 × 2.5 mm, Black Phillips Nylok coated screws with the Phillips #1 screwdriver, located on either side of the bottom of the screen.
      询问修复机器人
      添加评论
    3. Lenovo Edge 15 LCD Screen Replacement: 步骤 3 中的图像 1,1
      • Pry apart plastic cover at the bottom of the screen from plastic hinge cover.
      询问修复机器人
      添加评论
    4. Lenovo Edge 15 LCD Screen Replacement: 步骤 4 中的图像 1,1
      • Remove the (1) M2.5 x 2.5mm Black Phillips, Nylok coated screw located near the bottom center of the screen with the Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    5. Lenovo Edge 15 LCD Screen Replacement: 步骤 5 中的图像 1,2 Lenovo Edge 15 LCD Screen Replacement: 步骤 5 中的图像 2,2
      • Slide LCD screen around the edges while pulling upwards so that it pops off.
      • Turn the screen over so the touch board is visible, and start working from the back of the screen.
      • Ribbons will be connected in the back of the screen, so be careful not to pull too far that they rip out.
      添加评论
    6. Lenovo Edge 15 LCD Screen Replacement: 步骤 6 中的图像 1,2 Lenovo Edge 15 LCD Screen Replacement: 步骤 6 中的图像 2,2
      • Unplug the sensor from the sensor board near the bottom left of behind the screen.
      询问修复机器人
      添加评论
    7. Lenovo Edge 15 LCD Screen Replacement: 步骤 7 中的图像 1,2 Lenovo Edge 15 LCD Screen Replacement: 步骤 7 中的图像 2,2
      • Disconnect the two ribbons from connectors from the same board from the previous step, near the bottom left of the behind the screen.
      • The ribbon connectors unlatch by pulling up on the very small brown plastic bar near the end of the ribbon.
      • Be careful not to pull on the ribbons before unlatching. This may damage the connector and/or ribbons.
      询问修复机器人
      添加评论
    8. Lenovo Edge 15 LCD Screen Replacement: 步骤 8 中的图像 1,2 Lenovo Edge 15 LCD Screen Replacement: 步骤 8 中的图像 2,2
      • Remove the tape covering a ribbon connector near the bottom of the screen.
      • Disconnect the ribbon by pulling back the small grey latch on the connector and gently pulling the ribbon away.
      询问修复机器人
      添加评论
    9. Lenovo Edge 15 LCD Screen Replacement: 步骤 9 中的图像 1,3 Lenovo Edge 15 LCD Screen Replacement: 步骤 9 中的图像 2,3 Lenovo Edge 15 LCD Screen Replacement: 步骤 9 中的图像 3,3
      • Remove LCD screen by gently pulling screen away from the rest of the laptop.
      • Make sure all connections are secure when installing new screen. This eliminates the connection issue if screen is still not working properly after installation.
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
Cal Poly, Team S8-G1, Banghart Fall 2017 Cal Poly, Team S8-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G1
5 名成员
创作了63篇指南
5指南评论
Does the lcd separate from the digitizer screen or do both need to be replaced if the digitizer is cracked?
Sylvia Gagne - 回复 分享
Typically one can separate the LCD from the glass, but it is a difficult and painful process, and it almost always cracks the LCD. If the cost is not prohibitively expensive, I would just replace them together as one unit.
Allan Wilson - 回复 分享
I need that exact bottom frame strip piece replaced that they are showing in the first picture. Does anyone know where I can order one?
Josselyn Santiago - 回复 分享
looking to replace the whole screen, if possible even the hinge.
nasty bent screen I have for over 2+ years and I want to change that. Any advice welcomed.
frame is bent, Glass is broken in corner, touch screen gone.
Wouldnt care to install digitizer back but if I can see how to install screen components that be good.
Carry on.
Simarpreet Singh - 回复 分享
que tal joven talvez usted consiguió la pantalla y en que precio por que también tengo el mismo problema quiero cambiar toda la pantalla.
ToplayVid :v - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 56
总计 11,834
