跳转到主内容
加入维修社区 - 创建账户
Leica Z2X Flash Diffuser Replacement
你所需要的
    1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: 步骤 1 中的图像 1,1
      • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
      • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
      询问修复机器人
      添加评论
    2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: 步骤 2 中的图像 1,1
      • Open the back door on the camera by pushing down on the door latch.
      询问修复机器人
      添加评论
    3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: 步骤 3 中的图像 1,1
      • Apply pressure to the bottom plate and it will pop off.
      • From here, you can replace the bottom plate, or continue on to further steps.
      询问修复机器人
      添加评论
    1. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: 步骤 4 中的图像 1,1
      • Now that you've removed the bottom plate, you can pull apart the front and back covers.
      • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
      询问修复机器人
      添加评论
    2. Leica Z2X Flash Diffuser Replacement: 步骤 5 中的图像 1,1
      • Next, the back cover.
      • Apply pressure to remove the back plate.
      • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
      • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
      询问修复机器人
      添加评论
    3. Leica Z2X Flash Diffuser Replacement: 步骤 6 中的图像 1,1
      • You should now have removed the front and back plates.
      询问修复机器人
      添加评论
    4. Leica Z2X Flash Diffuser Replacement: 步骤 7 中的图像 1,1
      • Removing the flash diffuser should be simple from here.
      • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kenny
于04/10/11注册
57 声望
创作了3篇指南
团队
Cal Poly, Team 18-19, Garner Spring 2011 Cal Poly, Team 18-19, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G19
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 54
总计 3,943
